Spade connectors
Devonrod
Spade connectors
Post by Devonrod »
I am putting in a pair of new fuse boxes and need some decent crimp on fully insulated blue spade connectors, there is so much rubbish on sale, any recommendations please ?
thank you
Re: Spade connectors
Not overly fond of spades in general, especially the typical red/yellow/blue types. Pretty much all are crap really, and yes pretty much everything from China of poor quality
But you could maybe try this sort of thing, adhesive lined heat shrink connectors. I've never ordered from this place or used them specifically myself though. Although I have used other similar style connectors on occasion
https://www.force4.co.uk/item/Force-4/A ... ock=106131
Or other option is use a non insulated type, which at least allows you a direct crimp with the tool, and then use some coloured heat shrink over it.
https://www.12voltplanet.co.uk/non-insu ... minal.html
Or again you can do non insulated, with these little clear sleeves over them.
http://www.bluearan.co.uk/index.php?id=JAMFSA
Devonrod
Post by Devonrod »
Thank you
I buy mine from RS Components. Generally the RS Pro ones are OK, but to be 100% sure, get them from a good brand (anything other than RS Pro), and they'll be good.
Get the correct crimp tool which should cost you about £40.
