D1 3.5 V8 not starting
V8kiwi
Post by V8kiwi »
Hi All
New to the forum.
I disconnected my battery on my 1991 D1 3.5 efi to charge it and when I reconnected the battery she won't start.
Cranks over and I have good spark at the plugs but will not fire.
How do I check for fuel, I don't know anything about the efi system?
It doesn't have an alarm so I don't think it's an immobilizer issue.
Cheers Simon
Re: D1 3.5 V8 not starting
Any idea which of the EFi systems is on there?, flapper or hotwire?
Assuming Hotwire (as it’s the only one I know anything about) does the fuel pump run for few seconds on power up, you can normally hear it.
If so can you tell if it re-starts when the engine is turned over? As soon as you get a spark the pump should re-start, if not then the EFi is not getting that signal, the ignition is THE signal to make the system perform fuelling without it there’s no chance.
V8kiwi
Post by V8kiwi »
How do I tell if its flapper or hotwire??
From memory
The Hotwire system has 3 relays, one of them powers the fuel pump, I know I needed to replace that relay once.
There is also a black wire that goes to air flow meter, if you bumped that off by mistake the engine will not start.
V8kiwi wrote: Sat Jul 31, 2021 5:18 am How do I tell if its flapper or hotwire??
If it is 91, it won't be flapper. But not sure when GEMs replaced hotwire.
DaveEFI wrote: Sat Jul 31, 2021 8:49 am
Good point Dave, '91 is firmly in Hotwire teritory.
Other than that, difficult to explain without pictures, plenty of photo's on the Internet though.
Ian Anderson wrote: Sat Jul 31, 2021 7:03 am From memory
Hotwire has 2 relays specific to the EFi function, main and fuel pump, there are a few more but they are related to air conditioning mainly, they won't stop fuel running. About 3 of those, can't remember for sure as I don't have AC
If the fuel pump is firing up for 2-3 seconds when ignition initially switched on then both must be good.
Ian Anderson wrote: Sat Jul 31, 2021 7:03 am There is also a black wire that goes to air flow meter, if you bumped that off by mistake the engine will not start.
Cable going to flow meter has 4 (I think) wires, I suspect you possibly meant the single black/white wire going to the coil?
Yes. If it's like the flapper in that respect, a white/black wire goes from the coil negative via a plug-in inline resistor to the ECU. If that connection is bad it won't inject.
