Over Fuelling
jimthesail
Over Fuelling
Post by jimthesail »
Ahoy !
Before taking my HIF44s apart for the 5th time due over fuelling can anyone tell me where the bowl vent is please ? Suspect prob. is blockage ?
Free beer !
JimtheSail
Re: Over Fuelling
It's also called the fuel spill - a tube just below the dashpot that normally has a hose to carry spilt fuel away from the hot parts of the engine.
jimthesail
Re: Over Fuelling
May well be but where is it ?
I have vents to the rocker covers
Pipes that stick up at 45 degrees for the advance and retard and
the fuel supply.
Also a funny 'monkey face' boss on the side with holes in ?
JimtheSail
jimthesail
Re: Over Fuelling
Ahhh !
The two 'sticky up at 45degrees pipes ain't the vacuum advance take offs are they ??? Doh !!!
JimtheSail
Re: Over Fuelling
A picture might help better than "sticky up pipes" lol.
But that route to the fuel bowl should definitely not be connected to engine intake vacuum, or it'll likely suck a load of fuel in ! lol
Re: Over Fuelling
If you're applying a vacuum to the float chambers all sorts of odd things might happen. :D
Here's the best pic I can find - not a V8, but shows all the hose connections.
jimthesail
Re: Over Fuelling
Thanks for help. The overflow vent is the 'sticky up at 45 degree pipe which does not look as if it goes to the float chamber but it does and by blocking with vacuum pipe it caused pressure in bowl and flooding.
JimtheSail
