sprintex
Beastmaster
sprintex
I have recently bought a sprintex charger kit for an rv8,does anyone have any information regarding this blower,i have been on the sprintex website but there seems to be no information on the old u.k. models,i belive its a 102,but its specifficaly for the rover,c/w/ crank pully and inlet plenum,etc?
Hello Paul,
I have myself an efi kit and in fact it is the second S102 I buy. The first was for parts.
Which information do you need ? Which capacity engine do you intend to put the sprintex ?
I have some informations and dyno figures for sprintex on 3.5 and 4.2, also on ignition advance and pulley ratio.
Cheers.
Dimitri
Cheers.
Dimitri
Beastmaster
Dimitri ,im looking to fit it to a 3.9 Efi so any help is good
The seller says its a straight bolt on job with no internal adjustments,however the engine im going to use has been rebuilt with compo gaskets so that will have reduced the c/r slightly,the only other thing is what about extra fuelling under boost.
The seller is not too chatty as i have asked him about this but as yet no reply
Beastmaster
Better get back on the phone to emerald,mind you already sent one back that i didnt use on my cosv6,
how bout a perfect -power addon only a coupla hundred quid i think?
would the hot-wire system work out that it was getting more air and max out the E.c.u.,then top up fuel via PP
or is my voice muffeled by my underpants as usuall
your fuel curve from a standard ecu would be all wrong I don't think it would cope with the amount of extra power anyway. You cant mess with forced induction as it will just melt your engine if its wrong. You could get a hotwire chipped but by the time you pay for that there are other better alternatives out there. No point spending all that money on a charger if your going to waste power through not fueling it properly.
Beastmaster
Hello,katanaman wrote:Just call me Psychic or even sick lol. Your probably going to have to go mappable ECU to get the fuelling right. The TVR's that used these had a different ECU.
I agree with Marki, my own flapper system has an adjustable Ecu (DPR) and Jag injectors.
Paul, I have at this moment a little problem with computer to scan documents I have. Hope to be ok monday.
In all case the Man for sprintex is Dennis Priddle.
Dimitri
Beastmaster
Hello,
Definitively my scan is out
So post here some figures :
Stock LR 3.5/8.13:1CR/with twin HIF44 :
- Blower O/D 2.09
- ING Timing : 13 degre static - 26 degre total
- Max boost : 6.5 PSI
- 262LBS@3250RPM
- 222.6BHP@5000RPM
Stock SD1 3.5/8.8:1CR/with twin HIF44
- Blower O/D 2.1
- ING Timing : N.A.
- Max Boost : 6 PSI
- 272LBS@3250RPM
- 230.4BHP@5000RPM
Stock SD1 3.5/9:1CR/Flapper Efi
- Blower O/D 2.45
- ING N.A.
- Max Boost : N.A.
- 323.04LBS@3500RPM
- 285.46BHP@5250 - 303.14BHP@6000RPM
Stock 4.2/8.6:1CR/ with twin HIF6
- Blower O/D 2.54
- ING Timing : 13 degre static - 25 degre total
- Max Boost : N.A.
- 320LBS@3000RPM
- 272BHP@5000RPM
Cheers.
Dimitri
- Blower O/D 2.09
- 262LBS@3250RPM
- 222.6BHP@5000RPM
- Blower O/D 2.1
- ING Timing : N.A.
- Max Boost : 6 PSI
- 272LBS@3250RPM
- 230.4BHP@5000RPM
- Blower O/D 2.45
- ING N.A.
- Max Boost : N.A.
- 323.04LBS@3500RPM
- Blower O/D 2.54
- Max Boost : N.A.
- 320LBS@3000RPM
- 272BHP@5000RPM
Cheers.
Dimitri
bill shurvinton
Beastmaster
