P38 4litre oil pressure relief valve kit
Jimmyproductions
Post by Jimmyproductions »
Hello all,
Im new to the range rover life having just bought a Range Rover V8 p38. It's a great car. I bought it with a failed Mot. The top of the list is the oil leak above the filter housing. Having located the oil pressure relief valve as the culprit I removed the c clip and metal plug which houses the O ring or dried piece of noodle as it looked when removed. I've damaged the plug, having panicked when the darn thing wouldn't move so resorting to drilling and tapping a thread so I could remove the bleeder!
Can anyone tell me where I can get this plug, if that's what's its called, Rimmer Bros who are normally great can't help.
I'd be very grateful for your wise wisdom.
Re: P38 4litre oil pressure relief valve kit
The problem is that Land Rover don't list it as a separate item!
I have just looked at the parts catalogue for the Defender, the Disco 2 and the P38, and on all of them the timing cover is a complete assembly! There is no breakdown of the various valves, ports and seals in there!
So I guess that's why you can't find the info.
I suppose you could try someone like Turner Engineering who might be able to sell you the parts.
Mc Tool
Post by Mc Tool »
Cant you just tread a suitable grub screw into the hole , sealed with your fav goo?.
Next time blow it out with compressed air .
