LT77 Identification - again
Sorry - its a repeated string but can anyone positively identify where an LT77 transmission with prefix 35A originally came from and therefore the ratios inside?
Re: LT77 Identification - again
LDV400 if it's the same as the one mentioned in the 4th post here:
viewtopic.php?t=7540
if it is, then the low 1st gear should be easy to establish and might determine it's suitability for what you're using it.
