LT77 R380 parts interchange?
Im going to rebuild a R380, i have a good LT77 in bits, will the gears etc swop over? thanks
Re: LT77 R380 parts interchange?
I very much doubt anything more than some bolts will fit.
Contact https://www.ashcroft-transmissions.co.u ... -kits.html for spares.
In a work no, R380 is heavier duty so the gears are wider and the bearings are bigger. Unless the R380 was in a pretty shocking state I think you'd struggle to find an LT77 in better conditions.
I'm running an R380 now and I've rebuilt a few LT77's which can be challenging because a lot of LT77 bits aren't available anymore, unlike the R380 where you can still get pretty much everything.
