Hi.i have low vacuum on the offside carb on a rover 3.5 v8.The nearside has a lot of vacuum.It has zenith carbs fitted.could it be an air leak causing this. If so are there any common places for the leak to occur?
Thanks Matt
Low vacuum on carb
Re: Low vacuum on carb
I'm not sure if a split diaphragm can cause that?
