I have a trike,based on the following:
- Rover SD1 front right hub
- Rover V8 3.5l engine
- Borg Warner 65 autobox
- E-Type jag IRS
Currently overhauling the rear brakes/suspension. Oh, and unless you are a sadist, just leave the calipers/discs as they are.
I have a 4l lump in the back of the garage, but that has a habit of blowing water into No.3 when it gets hot
I reckon if I keep it below 88 DegC we should be ok. Just need to test the theory, once I put a new head gasket in.
