distributor identification
George B
Post by George B »
Hi, any one know how to identity if a Lucas 35DMB dizzy is for a carb or EFI engine, as I'm told the advance curves are different.
ratwing
Post by ratwing »
The bobweights on my distributor are stamped with a number (13°, times by 2 = 26° advance in theory), if they're all similarly stamped this may help you identify which is which?
Re: distributor identification
George B wrote:Hi, any one know how to identity if a Lucas 35DMB dizzy is for a carb or EFI engine, as I'm told the advance curves are different.
Different advance curves according to the CR on carb engines too.
George B
Post by George B »
Thanks for the replies guys 😆 the minefield just gets bigger😢 I was kind of hoping for a list similar to engine number ID's that tells what vehicle the engine was from😕
