My first involvement with a 4-barrel.
I have this 1404 I bought years ago for a previous vehicle but never fitted.
Was on a Rover V8, so the seller said, now it's going onto my SD1 3.5.
I want to use the PCV port which is in the front, or should be. There's an alloy plug in there, looks pressed in, not a hex, is it possible to remove it?
Would upload a pic but can't see how.
At the back of the carb in the corresponding position there's a 3/8" hose connector with a very small venturi. Presumably I can just blank that off?
Thanks.
Edelbrock 1404 4-barrel onto RV8.
Firstly, yes you can use the 4 barrel with the rv8. I have the 3.5 Vitesse engine in my Porsche 924 with an Edelbrock Performer intake manifold. As far as I can see the PCV port is pressed in, but mine is a hose attachment that I have capped, this is how they come out the box. I'm running a different breather setup (no longer the one in the pics).
The 3/8" hose connector on the rear is the vacuum port for a brake booster.
You can download a user / set-up manual from the Edelbrock website, very useful.
https://www.flickr.com/photos/144556909 ... res/76a0ed
http://www.edelbrock.com/automotive/misc/tech-center/
Ahh, thankyou.
Yes, that front port is the one I want to use, but there's no hose connector in there just an ally plug.
I'm using a JWR/Offenhauser dual-port manifold which has a rear port for the servo so I could blank the rear carb connector.
Otoh, I suppose I could put a bigger connector in the rear and connect it to the left rear rocker box via a pcv valve, and connect the air cleaner to the front right flame trap so the gases have somewhere to go at wot.
Very neat engine bay in your car. Was there a drawback with the catch tank setup?
Ivor
Ivor
88V8, SIII, Ambo 327
Unfortunately the hose on the catch tank were too small diameter so it was trying to blow out of the little mushroom inlet. Shame as it was such a neat looking solution. I now have 2 TVR style oil / flame traps that screw into the top of the rocker covers, one on each side and have topped them with to atmosphere breather filters. However I have not run this setup yet as the car is in pieces right now.
And as you've kindly taken the trouble to reply, you may find this interesting.
http://forum.britishv8.org/read.php?6,60224,page=1
Avoiding oil leaks is important, I guess, on a track car.. If crankcase pressure cannot escape via the scavenging system it will come out through the seals, and the resultant oil leaks I presume will fail scrutineering.
Which would be a pity.
Ivor
Ivor
