STATS AT 74C
mike-b
STATS AT 74C
Post by mike-b »
Looking for the above I come across the site mentioned below.
These stats are the standard size units, well it fits the Performer inlet manifold and so should fit the SD1.
Go here ... asap_supplies.com and in the search section enter 19931 Yes it is a boat parts supplier but they are the right size with standard pattern.
They are £7.50 each plus P&P & VAT needs adding. Buy two while you can get them.
Hope that helps someone.
Return to “Cooling Area”
