Hello
Neilr
Hello
Post by Neilr »
Just thought I say hi I have a 71 Rover 3500 P6. Have done quite a bit of work to it recently but still it doesn't run right. Hope someone on hear can help. Neil
Rover 3500 V8
Hello! Photos, and a description of your problem(s)?
Regards,
David
Neilr
Post by Neilr »
scudderfish wrote:Hello! Photos, and a description of your problem(s)?
Regards,
David
Problem is wont run without choke. Have so far rebuilt carbs and fuel pump changed cam followers and timing chain. Tried electronic ignition. And its still the same.
Rover 3500 V8
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
Hi and welcome to the mad house
If the followers were worn then the cam will also be worn, Rover V8's are notorious for cam wear.
Rossco
Neilr
Post by Neilr »
Rossco wrote:Hi and welcome to the mad house
Rossco
The worn cam was replaced with a new 3.9 cam from V8Tuner.
Rover 3500 V8
