96mm head gaskets?
- Seight-V8
96mm head gaskets?
hello all,
I'm looking for some head gaskets with 96mm bores, but only 1mm thick.....
Anyone else other than cometic make them....as these are now £110 each.....
things from the USA seem expensive at the moment.....and sending £220 on gaskets seems like overkill for what I will get out of them....
Must be cheaper options somewhere....
thanks
scott
thanks
scott
- SimpleSimon
Its not the protrusion into the combustion chamber that's the issue is the fact that there is a huge chamfer at the top of the bores, this means that even with a standard bore and a standard gasket half of the fire ring is not compressed at all between the block and the heads. I have had head gaskets fail because of this when using a 100 BHP NOS shot.
I think that over size gaskets are a good idea even on a standard bore, that way the fire ring is fully compressed. (Or deck the block to remove most of the chamfer!)
- SimpleSimon
I think that they put the huge chamfer on the bores so that the bloke fitting the pistons into the block could throw them at the block from 10 feet away and they would just fall into the bores!SimpleSimon wrote:Ah yes sorry, too use to seeing top hatted blocks or in my case severe deck reduction to the point my chamfer is near non existent, your correct of coursethat chamfer wasnt one of Rovers greatest moments and not necessary IMO
- SimpleSimon
sidecar wrote:I think that they put the huge chamfer on the bores so that the bloke fitting the pistons into the block could throw them at the block from 10 feet away and they would just fall into the bores!SimpleSimon wrote:Ah yes sorry, too use to seeing top hatted blocks or in my case severe deck reduction to the point my chamfer is near non existent, your correct of coursethat chamfer wasnt one of Rovers greatest moments and not necessary IMO
