P6 3500. Inlet manifold gaskets, thermostat and gaskets
- Helpful or Confused
Hi all, P6 engine runs strapped down on a trolley, but inlet manifold leaks coolant.
Recommendations please for good quality inlet manifold gaskets, thermostat, thermostat housing gasket, coolant temperature sensors and the two short hoses on the inlet manifold
Composite inlet gasket,use a little gasket sealer around the waterways,and on the end rubber seals.Other gaskets just use a good quality of eGay,the two small hose I used some short silicone
The inlet can be tricky,but perseverance we win the day !
I use a bit of sealer on the thermostat gasket too,
Others may tell you different,but that's how I seal it
