Hi there I'm modding my plenum so intake face out the front of the engine instead of out side so I'm buying a bolt on TB and wondered if a 70 mm tb would cause me any problems or would it be better I've got choice of 65 68 or 70 it's going to be twin turbo inter cooled it's 3.9 and want about 300/350 hp
Is single 70mm throttle body going to help or hinder
Twinturbotr7
- Helpful or Confused
Re: Is single 70mm throttle body going to help or hinder
You could make 1000hp with a TB that size blowing through it.Twinturbotr7 wrote:Hi there I'm modding my plenum so intake face out the front of the engine instead of out side so I'm buying a bolt on TB and wondered if a 70 mm tb would cause me any problems or would it be better I've got choice of 65 68 or 70 it's going to be twin turbo inter cooled it's 3.9 and want about 300/350 hp
Really...any of those sizes will be more than enough for a very modest power goal, both off and on boost.
Just use whatever is most convenient for you.
Twinturbotr7
stevieturbo wrote:You could make 1000hp with a TB that size blowing through it.Twinturbotr7 wrote:Hi there I'm modding my plenum so intake face out the front of the engine instead of out side so I'm buying a bolt on TB and wondered if a 70 mm tb would cause me any problems or would it be better I've got choice of 65 68 or 70 it's going to be twin turbo inter cooled it's 3.9 and want about 300/350 hp
Thanks for the advise I think 68 mm will fit nicer
So will go for that
Thanks again to taking the time to reply
I did the same modification you are doing but just used the existing throttle body which also incorporates a neat little idle control stepper.
http://forum.daxsportingclub.com/phpBB3 ... 5&start=70
