engine balancing
capriandyb1
engine balancing
Hi guys,dose anyone know a good place in Yorkshire to get the crank and conrods balanced,im fitting 96mm forge pistons to my vr8 4.6 and need it doing
Thanks in advance andy
Richard P6
capriandyb1
Iv phoned them today I can get it bored ut by them but not balancingRichard P6 wrote:I've used Rotherham Engine Supplies in Sheffield for my bike engine and they were very good; fitted new valve seats etc.. Don't know what they are like with engine balancing, but worth a chat as they are in Yorkshire.
0114 256 0056
11 Roman Ridge Road
Sheffield
South Yorkshire
S9 1GB
Basset down balancing in Hungerford for me,top bloke,top job
http://www.bassetdownbalancing.co.uk/en ... lding.html
John Sleath race cars in Doncaster
http://www.john-sleath.com/
capriandyb1
he balanced my parts two weeks ago been away on holiday,
capriandyb1
Right iv just spoke to john sleath he's happy to dyno it when finished but wount work on Brit engines only yanks now....hes got enough on with them to do anything else...soooo anywhere else.
Talked to chessman they want 600 just for balancing
Its starting to get to point in starting to feel is it worth it
capriandyb1
There is no easy answer to that. A bad tuner can break any pistons, as can a bad build.
But certainly I used standard low compression 4.6 pistons at around 15psi with no issue. The pistons are actually a pretty good design. I eventually blew it up, but it was no fault of the pistons.
Give Basset Down a call,they balanced,built and run mine in on a dyno !capriandyb1 wrote:Right iv just spoke to john sleath he's happy to dyno it when finished but wount work on Brit engines only yanks now....hes got enough on with them to do anything else...soooo anywhere else.
His name is Andy,tell him I sent you (Bryan)he's a dab hand with the Rovers, mines back there at the moment having a little work done
Give John Eales a ring. His brother does all his engine balancing and does it correctly with a proper individual internal balance. He did my TVR 5 ltr which needed a lot of metal removing from the crank and then a fair bit of heavy metal also adding. End result is super smooth. Wasnt expensive either approx £150.
Bill Eales at Midland balancing has done a few of mine. All good
