Just trying to work out what might be broken before I start tearing everything apart as its a huge job to get the clutch out of my car.
I cannot get the clutch to disengage, basically it feels like the pedal is not attached to anything. Its a cable not hydraulic, cable is not broken as the fork moves when pedal depressed but there is no resistance. It would seem that the fork is detached from the release bearing somehow. I had noticed that I was having to push my foot pretty much right to the floor in order to change gears prior to this happening.
Clutch will not disengage
Re: Clutch will not disengage
Sounds like whatever was wearing down and making it difficult finally failed.Prophead wrote:I had noticed that I was having to push my foot pretty much right to the floor in order to change gears prior to this happening.
Thanks for the replies.Darkspeed wrote:Could be so many things - a couple of which
1. Pivot ball has pushed through the arm due to fatigue
2. Arm has fractured at the pivot.
I have come to the conclusion it's probably one of the above. Regardless, as it's not the cable looks like I have to take half the car apart to get to it. So will plan on doing other jobs while I'm in there like rear crank oil seal ect
