A couple of years ago I had a thermostat housing altered by a alloy welder so the outlet comes straight out not cranked like the standard or indeed the housing that comes with the carb/manifold kit.
Problem is the vacuum advance module on the side of the distributor is now in the way.
BIG question is can I just rotate the distributor so the vacuum module is say 45 degrees (ish) further anti-clockwise then move all the leads accordingly? thus solving the problem.
I had the thermostat housing altered to help with cooling as the radiator is quite low, this way the housing is the highest point in the cooling system(apart from the header tank).
Any help would be gratefully received.
thanks
steve
