I have stripped the unit down and found a lot of disc run out. They are pretty new slotted and dimpled discs.
After repositioning the disc 90deg I have reduced the runout to about 6 thou or 0.15mm. It this good enough?
If not is it possible to get the discs ground?
Regards
