water pump leak
paulsv8manta
water pump leak
Post by paulsv8manta »
Hi, yet another problem has arisen!
installing water for the first time and I have water dripping out of the underside of the pump.
There appears to be a small hole not sure why this is here, but how do i stop it?
Hopefully i've managed to upload some photos.
Imagehttps://lh3.googleusercontent.com/S8LPR ... -h215-p-no
DEVONMAN
Post by DEVONMAN »
This means the seal in the pump is leaking. If you spin the pump it may seal up but unlikely. If the coolant has got into the bearings then the pump won't last very long anyway.
I've got several EFI water pumps here with the only fault being a leak. If only they could be stripped and new seals etc fitted.
They can be stripped - you can press the flange off the shaft, and then the shaft out of the bearing.
Not sure where new bearings and seals come from though.
paulsv8manta
I guess what I'm about to ask will be frouned upon. But I can't afford a new pump yet, and I really need to see if I can get the engine up and running. So can I plug the leak just so I can run in the cams?
How bad is it ? try some radweld ?
Unless it's absolutely running out of it, just ensure there is water in the system and running the engine will be fine.
DEVONMAN
Post by DEVONMAN »
If you plug the hole you will flood the bearings with coolant and wash away the special grease and the pump will definitely be ruined. If you do what Stevie suggested then there is a chance it will seal up after running for a while. It depends on what part of the seal is suspect. If it's the running surface it may seal up when running and pressure in the system can sometimes help the seal. If it's the seal surround that's leaking then there is no fix other than a rebuild or new pump.
Darkspeed
Post by Darkspeed »
As above see what happens with some heat and pressure
4.5L V8 Ginetta G27
paulsv8manta
The pump has been sat around dry for about 10years at least!
Now it's got water in it the leak has almost stopped. :)
Can I ask what water people are using in their rads? It's just I live in a really hard water area and I don't fancy the limescale build up in the engine. I know to avoid soft water from a softner because of the salt. I was thinking of filtered rain water as its a neutral ph.
Tap water
How many litres will it take?
And as it does not constantly have new water added the amount of lime will be minimal
Darkspeed
Post by Darkspeed »
Ian Anderson wrote:Tap water
With the correct amount of antifreeze - about a gram by my calculation !
4.5L V8 Ginetta G27
DEVONMAN
Post by DEVONMAN »
I may be wrong but my water softener uses the salt to clean the resin matrix and then flushes the matrix before it flows and begins to soften the water. Although it not recommended to drink the soft water, it does not taste salty. I use it to make tea.
paulsv8manta wrote:The pump has been sat around dry for about 10years at least!
If you're concerned, distilled water is best, or Halfords etc sell de-ionised water. Will do same sort of thing really.
Return to “Cooling Area”
