Welder advice
Welder advice
Chaps,
I have a trusty Clarke MIG 90 welder:
http://www.ebay.co.uk/itm/Clarke-Pro-90 ... ScS1CmGeEA
But I need to do a load of Land Rover chassis welding, and I don't think it's quite up to the job.
So I need a new welder.
I quite like MIG, but I rather think it's a bit obsolete nowadays. And sometimes I try to do aluminium.....
What should I buy?
Thanks,
What should I buy?
Thanks,
Hi Chris
I have a Sealey 180 set up here at home and it is a great bit of kit and I especially like the gun as the trigger is built into the handle.
A buddy of mine has a Cebora which is also a great bit of kit but the trigger is pooh and very flimsy
Both Lincoln and Miller do dual purpose ie mig and tig units but they are pricey.
Have a little look on some welding forums and see what the opinions are on them then go check out Ebay.
P
P
Most dual units will be DC only...ie no aluminium.
So really it's a case of buying a machine for the specific job in hand. I've had an old Murex 140A machine for over 25 years and it's been superb. Had a few minor niggles over the years, but it's still working well.
I've an R-Tech TIG for the alloy stuff, had it a few years too and no complaints. A few friends have used their MIG units too and always had good reports.
Their pricing isnt bad. 180A would easily cover anything you'd ever do on a car.
http://www.r-techwelding.co.uk/mig-weld ... -i-mig180/
But there is no way you'd be TIG'ing anything rusty at all, and it would be very awkward on car bodywork, as well as very slow. MIG is the best way.
Something with a good spread of power, and wire speeds.
http://www.mig-welding.co.uk/equipment.htm
Always worth searching here too, might even find a good used unit. The Volkzone deal via BOC also makes gas affordable, although places like Hobbyweld do no contract bottles too. Again, I wouldnt f**k about with CO2, get proper gas.
http://www.mig-welding.co.uk/forum/
Lots on that forum seem to like the PortaMIG stuff....Weldequip seem to run the forum and sell these and claim they're very good at low outputs, ie for thin metal which is handy for bodywork.
http://www.weldequip.com/portamig-165-mig.htm
Dont be under an illusion you need a welder with lots of nobs, flashy lights or stuff like that. I'm sure they have their place, but simple is good !
All MIG's are capable of alloy, but most will require a spool gun and a competent user. It aint for the faint hearted.unstable load wrote:I have a Matweld MIG and it is Ally capable. It requires reconnecting the leads with a jumper to reverse the polarity of the gun/earth clamp.
TIG ( AC ) is a much slower and for average user easier process as it gives the user far more control.
