Relays sharing power to pins 86 and 30?
baggers
Post by baggers »
Hi all, goal for this weekend on my Sebring v8 is to finish the wiring for the fuel pumps (one high volume feeding a swirl pot and a high pressure pump taking from that). After that I will be running out of excuses not to start it. :lol:
So a relay question. A simpler wiring solution for my situation will be to switch the earths on the pump relays. Now, question is as follows; so long as I fuse the feed appropriately from the power distribution board I will put in, can I relay share that power feed to pins 86 and 30? Given it is DC I cannot see why not, but your collective wisdom would be appreciated.
I have a switch for each fuel pump as I quite fancy the ceremony of a master ignition switch, 2 fuel pump switches and a push start. :D
Whilst we're here, will a Lucas Hotwire system be bothered if I pull out the built in loom fuel pump relay?
Thanks guys.
No reason not to share the main and coil power if that does what you want.
It's common to arrange things so the pump stops with the engine - to prevent spilling fuel in event of an accident, etc. Your hotwire will already do this.
The Hotwire fuel pump relay is happily powering both my Facit red top circulating to my swirl pot and also the Bosch044 high pressure pump
