typical decking amount
- Seight-V8
hello all,
Does anyone know how much they normally deck the block head faces after fitting top hat liners?
Taking block to chesmans later this week and forgot to ask.
scott
scott
kokkolanpoika
- Seight-V8
- Seight-V8
Had by block top hatted by chesman's in Coventry yesterday, and they've done an excellent job, with excellent service.....
Will recommend them anytime.
Just need to measure how much was removed from the head faces during the decking, as the engine number has now gone too.....
Then I can work out compression ratios for the next part of my re-build.
I am hoping the decking was minimal but I am not too sure.
regards
scott
regards
scott
- SimpleSimon
I have notched pistons with a 238 cam and my limitation was not VTP clearance although getting marginal it was piston to head clearance
as my pistons pop out of the block I am just outside the considered minimum
but mine is a 4.0 I removed about 1.3/1.5mm from the decks IIRC which also gives the usual inlet manifold issues that had to be corrected
