Ported Supercharger ?
Wotland
Post by Wotland »
Hello,
Someone here has already used an ported supercharger with good result ?
Apparently It is an popular upgrade on Eaton M90/112 supercharger. http://www.stiegemeier.com/
What I have understood porting can't make it deliver more air as they are positive displacement supercharger but it can increase it's efficiency. This means that it will require slightly less power to drive the supercharger and the temperature of the air leaving the supercharger should be reduced. The main advantage of this improved efficiency is that you can now drive the supercharger faster without excessive power consumption or outlet temperatures.
Cheer.
Return to “Forced Induction”
