Folks, got an urgent issue....
I have a friend who has a pair of heads with the threaded ports for the pulsair air injection pipes just above the exhaust ports, but the thread size seems a larger diameter than other heads I have previously seen with this arrangement. I don't have the heads in front of me to check, but it would appear to be a similar size to a spark plug thread - can anyone confirm this please, or tell me the exact thread size?
Thanks in advance.
Air inhection thread sizes
badger
Cheers ged, that's the smaller size blanks, used on the pulsair systems that have 4 pipes per side. The ones I'm needing are an oddball - the system used on late model V8 defenders that only had 3 pipes connected per side. Apparently, they sussed out that due to the firing order and pulses, this was more efficient, but they changed the thread size at the same time!
