1979 mini van
V8 Only Please,
andyv8van
1979 mini van
Post by andyv8van »
Hi This is my 3.9 rover ,mini van "The Beast"
Andy
3.9 V8 Mini Van....THE BEAST
mikeinatruck
Post by mikeinatruck »
Now that is one mean machine, I like it a lot... I had a 1380cc mini van once thought that was fast, used to rev to 9k but very very scary sounds at that speed.
Wish I could have done the V8 thing though Bravo.
andyv8van
Post by andyv8van »
Hi All
made a new steel front spoiler for it.dropped the front down 50 mm i think it looks a lot better
fitting this th350 gearbox to the engine now...lol
Image :lol:
Cool :D
so when making the adapter, how do you get it perfectly centered?
Lewis
Post by Lewis »
That's FANTASTIC! :D
andyv8van
Post by andyv8van »
hi eliot
the first thing was to measure both engine and box to get the plate correctly placed.The plate was then made to fit the engine mounting holes and fitted to the locating pins.always in the correct place now.the geabox convertor was removed and i fitted a machined sleeve to the pump shaft with a end piece pressed into the end to match the hole in the engine crank.
this then makes the box fit correct to the engine.i then leveled off the engine and box.i had also to make some gearbox pins that had a small hole drilled in them to mark there position on the spacer plate.the mounting holes on the plate were drilled with a 7/16 drill to centre the holes b 4 drilling them for a 10mm thread.now the outside is getting cut off to make a neat job.
easy as that....i wish.........lol
Andy
just see your web site.
did you change the bush`s on your th350 box?
NorthernBloke
Post by NorthernBloke »
This is proper mental - Love it 8)
Andy
leepop633
Post by leepop633 »
Like it alot. :D
I do erratically, often with bits falling off.
andyv8van
Post by andyv8van »
just got some shifter brackets from USA for the gearbox,fitted and its working okay, in all the manually shifted gears now.
Andy
tetlow
Post by tetlow »
Andy
It looks fantastic. Any pic's of the interior?
andyv8van
Post by andyv8van »
Hi Dave
not a lot of room.going to work on the interior a bit more to make driving it better over long journeys,the pedals and seat position dont help,but its tight for space.
Andy
tightenloop
Post by tightenloop »
realy hot
пиздец!!!
DM
Andy
What paint is that mate?
Notice how the sun turns the Red to Orange on the console in that pic!!!
mine does the same Perry,
its the colour pigment,
Return to “Your Cars”
