Recomendations For Engine Block Work
After some recommendations for companies regarding block work local to Berkshire if possible,
Need block faces skimmed where liners sunk,
slight rebore to take new pistons,
offset grind my crank,
balance the whole assembly.
v8250
Post by v8250 »
Have you tried James Goldstraw at Grace Engineering in Newbury? Call on 07779.223001. If good for you, say Andrew forwarded contact details.
Note: if urgently required do be careful as they're constantly flat out - they do need pinning down on completion date...but no different to most engineering houses.
Also, FJ Payne in near Witney...a little further but also very good.
thankyou.
You could try Roland Alsop, ask for Steve
http://ukplaces.com/Engine%20Rebuilders ... nd-l-alsop
Bit further away, but Chesman engineering usually got a good rep too ?
yeah was looking towards chesmans funny enough,
need to get this engine block sorted,
Return to “General Chat Area”
