Just about to connect the high pressure fuel lines to my 3.9 hotwire v8 in my Dax Rush kit car, my query is one of the orginal fuel lines ( I think its the inward one) has the threaded connector crimped allowing it to connect to the fuel rail, does anybody know the thread size etc of this connector and where I can get another one, and does it need to be a crimped on type, as the other connectors that goes to the fuel regulator (I presume thats what it is) and those on the hign pressure pump (bosh) are of the push on type that are secured with a jubilee clip.
Cheers in advance
Leigh
Fuel line connectors on 3.9efi
- vdub boy 1
I cut the "nut" part off
Then just used push on with a Jubilee clip. - It seems to be doing fine!
- vdub boy 1
