Help
tinker
Help
Post by tinker »
I have a trike with a rover V8 and an borg warner 65 auto box , i had lots of smoke and grinding noise from the box I'm presuming it's shot and have been quoted silly money for repairing for what in reality is a rat bike . So far I have manage to get three replacement boxes two wear too long and the bellhousing wasn't for a rover and the other is actually a borg warner 35 ( which from what I've been told is the same as 65 without oil cooling ) but doesn't have any bellhousing .
The trike was built around the engine , box and back axle so need something the same size , has anyone got any advice / ideas for what to do ?
I need to keep it auto as the drivers seat is on top of the box .
Tinker
P.s. This is my first post on here so If I've broken any rules and posted in the wrong place sorry .
JSF55
Post by JSF55 »
By chance a BW 35 bellhousing and convertor came up on the nsra yesterday if you want to go that route
http://www.nsra.org.uk/newforum/showthr ... -converter
So thats where it went !
harvey
Post by harvey »
The BW35 is a lot wider than the BW65, so if your tunnel/chassis has been closely built around the 65 you probably won't get a 35 in there. The 35 isn't as reliable as the 65 either.
Can you rebuild the box yourself?
tinker
Post by tinker »
ChrisJC wrote:Can you rebuild the box yourself?
Wish I could but I've seen it in bits there are hundreds of them , there's not a cat in hells chance of me doing it .
harvey
Re: Help
Post by harvey »
tinker wrote: and have been quoted silly money for repairing for what in reality is a rat bike . So far I have manage to get three replacement boxes two wear too long and the bellhousing wasn't for a rover and the other is actually a borg warner 35 ( which from what I've been told is the same as 65 without oil cooling ) but doesn't have any bellhousing .
Whereabouts are you? Maybe you're close to someone on here who would be able to help you out a bit.
Obvious way is to just get another BW 65 which is standard SD1. They tend to fetch less than the later GM box - but neither will cost you as much as a re-con, even when doing it yourself. But of course anything used is a gamble.
As regards overhauling your own box, it looks much more difficult than it is. But you do really need a manual giving the sequence for stripping and overhaul etc. You also need to keep things very clean. So not something you can do in the street.
harvey
Post by harvey »
DaveEFI wrote: As regards overhauling your own box, it looks much more difficult than it is. But you do really need a manual giving the sequence for stripping and overhaul etc. You also need to keep things very clean. So not something you can do in the street.
+ the installers to get the resealed pistons back into the drums.
Return to “General Chat Area”
