Tuning Megasquirt
sowen
Tuning Megasquirt
Post by sowen »
A little advice/opinion wanted please, I've been fitting a Megasquirt system to my SD1 V8 over the past few months, it now runs, has an acceptable idle and drives ok up and down the road. I'm still reading and re-reading the tuning instructions with TunerStudio that came supplied with my ecu.
Is it worth registering TunerStudio and upgrading to the autotune stuff that they offer? I can continue to spend all my evenings and weekends staring at a laptop randomly changing settings hoping I eventually hit the nail on the head, or take advantage of the software available and get it heading in the right direction quicker?
I don't want to go to a pro or rolling road as I continually change, adapt and modify things, and have at least one other project that could benefit from going fully mappable efi :)
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
IMHO very worth having autotune and the logging facilities. But I've never had Lite, so don't know what I'd miss most.
Warm up autotune which was added fairly recently I found particularly useful.
Other thing is new facilities are being added all the time, often after requests from users. And this can only really happen if money comes in.
SimpleSimon
Post by SimpleSimon »
DaveEFI wrote:IMHO very worth having autotune and the logging facilities. But I've never had Lite, so don't know what I'd miss most.
Got to agree with Dave on this :D its a cracking bit of software and makes MS all the better 8-)
The autotune worked great for me, in one drive it transformed my engine, I would recommend it.
Spongo
Post by Spongo »
Yup deffo register its a cracking piece of software and does what it says on the tin, you do need to get the car running reasonably well first but it certainly makes the tweeking all the easier and you get updates etc and new stuff thrown in.
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
Quagmire
Post by Quagmire »
Another happy customer here, definitely worth the money!
1974 Rover 3500s
1984 3.5 90
1959 2.25 series 2
Question here
I would look at MS etc but was always told that you spend ages putting the right numbers ito buckets to make the thing run right
So is this not a problem of the past
Plug in the computer - go for a run up holl down dale traffic lights hot engine / cold engine motorway, blast etc and it sorts out the tuning?
So it will guarantee no melted pistons, reasonable economy and power?
no this is for the tuning of the MS after you have ticked all the boxes, set up the tach signal conditioning, selected all the options and debugged it.
best regards
Ian Anderson wrote:Question here
There are tools in TunerStudio to calculate basic AFR and VE tables, based on the figures you enter for engine size, BHP, torque etc. There is also one for 'required fuel' which is a constant based on engine size and actual injector flow. Between those, you'll normally end up with an engine which runs. They tend to err on the rich side to avoid piston damage.
I've found it pretty quick and easy to get an engine running well. Tuning it also for best economy takes rather longer. :D
sowen
Post by sowen »
Cool, so it does appear to be a good idea to register :D
I've only done a gentle drive round the local area, and it pulled ok, but I have to be very gentle where I live being in the centre of a residential area and the main road is often used as a racetrack :? so no more than a light dab of the go pedal to roll around.
A few more local runs out on the back roads should confirm the basics are there, then I guess it would be ready to try out the autotune to refine it a bit more :)
The auto tuning section - VE Analyze live - relies on values that YOU input for the AFR table, it basically looks up the AFR at that instant in time / load / rpm and adjusts the fuel (VE) to try to correct the AFR. When you're driving the more time you spend at a particular load/rpm site the more accurate the adjustments.
It can tune for economy, just depends on what AFR values you enter. I didn't find it so useful for higher load tuning as I just couldn't spend enough time in that area of the map (end up going too fast!) If you could find a really long hill that might help!
There is also warm up enrichment auto which I haven't used yet but looks to be quite handy.
I've used the warmup autotune and it's very good.
sowen
Post by sowen »
SuperV8 wrote:The auto tuning section - VE Analyze live - relies on values that YOU input for the AFR table, it basically looks up the AFR at that instant in time / load / rpm and adjusts the fuel (VE) to try to correct the AFR. When you're driving the more time you spend at a particular load/rpm site the more accurate the adjustments.
Interesting point about holding the rpm/load steady, makes sense to let the afr readings settle to sort itself out.
Amongst my bag of tricks I have a reasonable length runway possibly at my disposal if I ask politely :wink:
Cobratone
Is a Spanner
Post by Cobratone »
As said above, Autotune is good but ONLY if you have a good AFR table as it tunes to match that. Spend some time getting that right and autotune will be your best friend 8-)
cammmy
Post by cammmy »
How can you dial in the timing properly without a dyno? Wouldn't it be worth getting a good base on the dyno? Then your tweaks/mods wouldn't require as much to account for.
