I've decided I want to replace the worn out axle on my SD1 with a hybrid axle based on a Scimitar 4HA axle, using a Jaguar LSD and 2.88 ratio gears. After a lot of research I've ordered a pair of Jeep Grand Cherokee front hubs as they are already 5x5" pcd, and should be easily mounted to the axle casing to give a full-floating setup. This leaves the halfshaft/driveshaft which will need to be a custom made shaft.
I've e-mailed Dave-Mac propshafts, I've used them before and they're local to me and am awaiting a response (wrong time of year for that).
Are there any other recommended companies who could manufacture a pair of driveshafts, and what price should I expect to be paying?
Custom driveshafts
Custom driveshafts
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
You could try Andy Robinson Racing, I've no idea what he would charge...
http://www.robinson-race-cars.co.uk/
Thanks for that, just sent them an e-mailsidecar wrote:You could try Andy Robinson Racing, I've no idea what he would charge...
I'll keep Hauser in mind, had a reply back from Andy Robinson so will be calling them on Mondaystevieturbo wrote:ARRC and Hauser etc can supply Moser shafts.
Made to any shape/size really, and not overly expensive
I'm sure either could sort you out
I got my custom Moser shafts made via Webster Racing. Moser copied them in the USA ans shipped them to Websters. This was about 3-4 years back and they cost around £500.00 back then. FYI
Ouch! Not cheap but if buying once for something that should last and take practically anything I throw at it can't really grumble at those prices! Would mean I'd have to possibly wait a little longer to save up some spare cash, or work my socks off over Chrimbo and January
