Nitrous on a ITB setup
I thought that I had seen (some time ago I must add) an injector that fired both fuel and nitrous but fitted in a normal fuel injector type space. So basically, you take your normal injector out, fitted this new injector in place and connected up the lines and control but I can't see any reference to anything similar on the net. Anyone heard of such a thing??
Big Tone
www.cobratone.co.uk
www.cobratone.co.uk
You thinking of sticking NOS on your Cob?
I would have thought that you could just get your 'normal' injectors to fire in the extra fuel when the NOS is running, all you need then is a load of foggers to inject the NOS. If you are going for a reasonable BHP shot then you will need to back off the timing a few degrees when the NOS is running.
Basically this is what they call a dry system.
EDIT... Actually I think "foggers" deliver both fuel and NOS.
You are talking about the NOS Noszle system Tone.
Heres a link
http://www.mustangandfords.com/how-to/e ... us-system/
Heres a link
Hi Pete, yes I can get the current injectors to fire the extra fuel (dry system) I was looking at a way of getting the nitrous injected without having to drill extra holes in the manifold to fit foggers. Thanks anyway.sidecar wrote:You thinking of sticking NOS on your Cob?
Big Tone
www.cobratone.co.uk
www.cobratone.co.uk
Cheers Pel, seems a way of doing what I want but wasn't what I was thinking of. Like I said, I may have dreamt the whole fuel and nitrous combined injectormgbv8 wrote:You are talking about the NOS Noszle system Tone.
Heres a link
Big Tone
www.cobratone.co.uk
www.cobratone.co.uk
Following on from Perry's post, I found these which may be a cheaper and simpler way of doing it as I won't need any extra fuel lines then, the ecu can do it
http://www.p-i-fuelsystems.co.uk/crossjet.htm
Big Tone
www.cobratone.co.uk
www.cobratone.co.uk
