3.9 V8 Serpentine to V belt help
Posted: Sun Sep 21, 2014 12:45 am
by keefy
can you convert 1996 rover 3.9 v8 serpentine to v belt? if so what parts are needed?
also is the sd1 water pump the same as the p6?
Thankyou
Re: 3.9 V8 Serpentine to V belt help
Posted: Sun Sep 21, 2014 2:58 pm
by harvey
keefy wrote:also is the sd1 water pump the same as the p6?
No.
Posted: Sun Sep 21, 2014 5:07 pm
by mgbloke
Yes you can.
I used a P5 pulley that I had shortened. The pulley just drives the alternator which sits low in front on the passenger side.
The water pump is an Electric Davies Craig 115 which has been reliable for the last 4 years.
Mark
Posted: Sun Sep 21, 2014 7:18 pm
If it's a full serpentine, i.e. just one wide belt, then it's a pretty major change. You need a new timing cover and all the ancillaries / brackets etc. The water pump is also different, so hoses may need changing, as may cooling setup.
There are different crankshaft ends to suit different arrangements, so you might fall foul there too!
Posted: Mon Sep 22, 2014 8:56 pm
by topcatcustom
Serpentine fronts have water pumps that run anti clockwise, V-belt water pumps run clockwise, so it's not an ideal swap. Personally I would rather run a serp belt, less power loss, sprung tensioner means no maintenance and just a nicer more modern look!
Posted: Wed Sep 24, 2014 8:44 am
by paul c
to swap a 96 serp to v belt you will need the timing cover, water pump, accesories and pulleys, the crank snout is the same so nothing needed there, the distributor will also need a drive dog for the oil pump.
Posted: Wed Sep 24, 2014 9:10 am
by topcatcustom
I'm sure the cam nose is completely different too- the serp ones are shorter as they don't have a drive gear on the end for dissy and oil pump.
Posted: Thu Sep 25, 2014 10:50 am
by paul c
topcatcustom wrote:I'm sure the cam nose is completely different too- the serp ones are shorter as they don't have a drive gear on the end for dissy and oil pump.
96 3.9 should be an interim engine so has serp drive belt, crank driven oil pump, distributor driven from cam.
