can you convert 1996 rover 3.9 v8 serpentine to v belt? if so what parts are needed?
also is the sd1 water pump the same as the p6?
Thankyou
3.9 V8 Serpentine to V belt help
Re: 3.9 V8 Serpentine to V belt help
No.keefy wrote:also is the sd1 water pump the same as the p6?
If it's a full serpentine, i.e. just one wide belt, then it's a pretty major change. You need a new timing cover and all the ancillaries / brackets etc. The water pump is also different, so hoses may need changing, as may cooling setup.
There are different crankshaft ends to suit different arrangements, so you might fall foul there too!
- topcatcustom
- topcatcustom
