Rebuild continues, RR is a 1989 flapper, found this exhaust sensor already fitted. Possible that the exhaust is a later addition. Any suggestions as to whether this is a wideband or narrowband sensor?
[/URL][/img]Moderator: phpBB2 - Administrators
[/URL][/img]
Yes they did. The forerunner of the UK flapper was the NAS SD1 which had lambda sensors. If you look inside a UK flapper ECU there is quite a large part of the PCB unpopulated - that's where the sensor electronics go.ChrisJC wrote:I can't remember if the flapper ever had a Lambda sensor option. I think it might have done in some export markets. But presuming it is a UK market system, then the sensor must be an aftermarket one, most likely wideband.
