For now as I need the car for work I have removed the MS and reconnected the MJ, which is running perfectly - i.e it has an RPM signal.
So I have finally got around to getting my freshly built MS2 in the car - but I have no RPM. The car runs, as It was on Megajolt before and still has the SU's, so I know the EDIS wiring is sound.
The ECU works, as I flashed it with 3.3.2 ok. I can connect it to the PC and tweaking the pots on the stim (Megastim 2.21) shows changes in IAT, CLT, TPS etc. I can read from it and burn changes to it as normal too. I get no RPM on the stim, but never did on my previous MS1 builds. Should I see an rpm on the stim now that I am using the VR circuit to as input?
I followed the manual, and made the mainboard changes as per section 5.2.4, and 6.7.2, including the twiddling of the pots anticlockwise 12 turns and the bottom one 6 turns back.
I have setup the software side of things as per the manual as well (hopefully) - see attached msq.
I have the PIP and SAW connections on pins 24 and 36 of the DB37, and have done a continuity test to confirm.
I have tried swapping the PIP and SAW wires over to the MS, no change.
Can anyone suggest anything I have missed? Photos of board attached, and MSQ.
Also worth mentioning the following two facts that may be related:
On assembly I noticed that D18 was slightly chipped at the end out of the bag,
and
I noticed just now that the TPS gauge continually climbs very slowly when on the car, even though it is not connected to anything at present. This may be normal though as it behaves on the stim ok.
Many thanks
Jamie
