Hello everyone its me again back for a little bit more help,
im upgrading from a 35DE8 to 35DLM8,anybody know how easy it is,
im assuming its just wiring,anybody got any diagrams that would help,im guessing i will need to get rid of the ballast resistor i got at the moment
Wiring for uprade from 35DE8 to 35DLM8
markmills2000uk
markmills2000uk
markmills2000uk
markmills2000uk
Mine has a 35DLM8 using an amplifier module with the mini-timer style connector rather than spade terminals. The connector supports three terminals but only two are actually wired up, and these go to the coil +ve and -ve as pointed out earlier. The coil -ve is also wired up to the ECU trigger wire and the tacho input.
