R380 gearbox
R380 gearbox
Does anyone have info about R380 gearboxes fitted to LDV vans, do they fit straight on a Rover V8? ive trawled the net and as usual there are conflicting opinions.
The pinion is marginally longer on the R380 than the LT77, I don't think it's an issue on the V8, but some engines that orignally had an LT77 it binds on the end of the flywheel. I had to make a thin spacer shim to go between the bellhousing and gearbox for a T16 engine. The selector mechanism sits about 1" further back and the rear mounting is different. Overall length and general size/shape is the same.
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
