putting 4.6 crank in earlier block
neal1980
Post by neal1980 »
Im sure this has been covered before, anyone know how much i should be looking at paying for somebody to machine my large journal 4.6 crank to fit my earlier 3.9 block. Is this all i need to do then use the 4.6 rods and pistons??
Ive read I may have to grind a bit out when its turning im ok with that.
Or can anyone recommend a place to do it, distance no object really as i have a good courier just want it to be spot on.
Neal
ihatesissycars
Post by ihatesissycars »
It depends on what 3.9 block you have.
If you the first of them then you need to have the mains turned down and loads of material machined off the counter weights and then a rebalance with lots of heavy metal put in.
The second/middle type just needs the mains turned down.
The third and last of the 3.9 blocks is basically a 4.6 block just not cross bolted (but has the provision to do so) and has the same size mains as the 3.9 block. This one you can either just turn the mains down and in it'll go or you can have the the block line bored and the holes drilled and tapped for cross bolting at the same time and again in the crank will go.
If you have the first type of block then its a gamble in regards to if it can be rebalanced after counter weight machining. Or so i've been told. I wouldn't bother if you have that one. It'd be cheaper to get a crank from JE made to suit.
Boosted LS1
Post by Boosted LS1 »
Or, instead of removing loads off the crank journals you could line bore the block and mill some more bearing locating slots.
Boosted.
ihatesissycars
Do you know anyone that can do that Mike?
Boosted LS1
I'll check and post later today. I should be able to do it.
ihatesissycars
Wicked! I need it done to my spare block!
me too possibly
neal1980
Post by neal1980 »
any updates on this ????
ihatesissycars
I'm not anymore, I still have the spare block but I've sold the crank and rods.
