Intake for MGB GT
task
Intake for MGB GT
Post by task »
I'm at the stage of my V8 MGB GT where I need to choose a bonnet and the engine top end parts.
I was set on hotwire EFI but the cam I ended up installing was a piper 270 rather than a 270i so I am considering a 4 barrel carb.
What intake manifold is likely to fit under the bonnet of an MGB (either the MGC bonnet/Costello bonnet or the RV8 bonnet)
I've been looking at the Edelbrock 500cfm carbs and Edelbrock 180 Dual Plane manifolds...
1991 CSK Range Rover - 4.6 Stage 3
1998 Discovery 3.9
1979 MGB GT - V8 conversion
ppyvabw
Post by ppyvabw »
Mine has the Offy Dual port. Not a real good performance manifold apparently, but it's ok and it is the lowest manifold. On top of that is an eddy 500 and the 2 inch air cleaner. Clears an MGC bonnet, but the carb isn't level and I had to cut the wings off the air filter wing nut lol. I slightly lowered my engine mounts too.
