in need of a speedo
Posted: Fri Apr 04, 2014 10:57 pm
hi guys, picking all your brains need a new speedo for me truck, just curious as too what you can recommend its a 100m speedo, SD1 V8 mated to an LT77
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
https://v8forum.co.uk/forum/
So you have a speedo already ?series3-2007 wrote:hi guys, picking all your brains need a new speedo for me truck, just curious as too what you can recommend its a 100m speedo, SD1 V8 mated to an LT77
It does +/-100%DaveEFI wrote:Jaycar do a converter which takes in the pulses from a sensor and either multiplies or divides them - adjustable about x3 in either direction. Allowing near any electronic head to be used. Probably costs less than having a mechanical one re-calibrated. If you have no speedo drive at all it will work with toothed disc on the prop and a hall effect sensor.
Ah - failing memory.stevieturbo wrote:It does +/-100%DaveEFI wrote:Jaycar do a converter which takes in the pulses from a sensor and either multiplies or divides them - adjustable about x3 in either direction. Allowing near any electronic head to be used. Probably costs less than having a mechanical one re-calibrated. If you have no speedo drive at all it will work with toothed disc on the prop and a hall effect sensor.
I have one...that said, last few times Ive checked their site it always says no stock.
So it's maybe been discontinued.
