in need of a speedo
series3-2007
in need of a speedo
Post by series3-2007 »
hi guys, picking all your brains need a new speedo for me truck, just curious as too what you can recommend its a 100m speedo, SD1 V8 mated to an LT77
Re: in need of a speedo
series3-2007 wrote:hi guys, picking all your brains need a new speedo for me truck, just curious as too what you can recommend its a 100m speedo, SD1 V8 mated to an LT77
So you have a speedo already ?
Or you need one that size ? mechanical or electric ?
Blown v8
Post by Blown v8 »
Mechanical ones can be re calibrated,speedo cables can be custom made,
I always use speedycables
Jaycar do a converter which takes in the pulses from a sensor and either multiplies or divides them - adjustable about x3 in either direction. Allowing near any electronic head to be used. Probably costs less than having a mechanical one re-calibrated. If you have no speedo drive at all it will work with toothed disc on the prop and a hall effect sensor.
DaveEFI wrote:Jaycar do a converter which takes in the pulses from a sensor and either multiplies or divides them - adjustable about x3 in either direction. Allowing near any electronic head to be used. Probably costs less than having a mechanical one re-calibrated. If you have no speedo drive at all it will work with toothed disc on the prop and a hall effect sensor.
It does +/-100%
I have one...that said, last few times Ive checked their site it always says no stock.
So it's maybe been discontinued.
Either ETB in the UK easy to deal wit
http://www.etbinstruments.com
or speedhut in USA
http://www.speedhut.com/gauges/
JSF55
Post by JSF55 »
Speedhut :D
So thats where it went !
Lots of USA GT 40 and similar cars are running the GPS speedo
Will find the satellites within15 secs of starting supposedly - unless you live in a long tunnel
It does +/-100%
Ah - failing memory. :D -/+ x2, then.
I've got one here - would be easy enough to copy the PCB if needed.
