Hello just joined the forum, I have a Range Rover with a 6.3l Chevy Engine using an MS2 and no doubt once Shaun sees that I am on here he will ruin away to say it has been a bit of a nightmare is an understatement
Vortec heads and a TPI inlet manifold, TPIs are the earlier bolt pattern manifold so yes it would need adapter plates as you have found.
best regards
you can hide the lines and the nozzles very neatly on the lower part of that TPI manifold just need to tell the MSQ when you activate it, and maybe fit some bigger injectors oops I seem to have started again
best regards
