Big thanks to Ray at V8Developments and Shaun from MS2Tuning.com
Engine is 5325cc RV8 (V8Developments) with 8psi of boost from a Rotrex C38-81 into a charge cooler. Fully Sequential injection / Ignition using one of my MS3 ECUs.
Sounds like your heads are maxing out on flow there Tony. Your engine should be capable of 7k rpmCoops wrote:Shaun and I have a few more tweaks to do first,
then it should be ready mate.
mines topping out at 5830rpm this is where the boost levels off and no more is being made,
But im happy its giving me 14psi
That might not be an issue for long cause according to another post some Merlins might come up for sale soon...Rossco wrote:
Rossco wrote: It would be interesting to see if by reducing the pressure you moved the max flow point up the rev range and therefore released more power.
