Zinc coated hubs or something?
Hi, I've got these custom hubs for the MGB but they're a little rusty, nothing a quick sandblast wouldn't sort out before new bearings & I refit them, problem is they'll only go rusty again, is there anything I can do to prevent this? Some kind of zinc coating etc or will that just come off? I'm obviously worried about the bearing surfaces being left as well.
If not no worries not the end of the world!
- topcatcustom
Could you recommend a decent spray chassis black, or is it better to use something like brush-on; POR15 etc? Not had any experience with that as yet but I have a lot to do (entire front & rear ends)DaveEFI wrote:A decent chassis black will last for ages. Use an acid etch primer first.chodjinn wrote:If I was to paint it myself what paint should I use?
