Lambda probes. How close can they be to the exhaust port ??
As per the title. How close can i fit my probes to the exhaust ports??
I'm going to relocate my two probes while testing the zoomies and I have the choice of fitting them between 5" and 20" from the exhaust ports.
The blurb on the probes says operating temp 930C and max temp 1030C.
I've never measured EGTs on the Rover engine when racing. And I dont want to knack anything. EGT on nitrous should not really increase much. But I'm running nitrous on top of boost as well.
generally you dont want to heat the sensor more than around 750degC
So if you insist on putting them close to the ports...be prepared for the sensor not lasting long, and possibly less accurate.
It would be easier to leave the lambda sensor further out, and monitor EGT's on all cylinders for fine tuning.
One lambda per bank, and 8 x EGT's
Sorry Stevie
I didnt make myself clear.
I'm not looking to log EGT's at the moment. I'm just wanting to re fit the lambda's where they will work but not get fried.
If I can keep them within say 6" of the exhaust ports they will still be under the bonnet when the zoomies are fitted.
Perry
mgbv8 wrote:Sorry Stevie
Perry
Are you talking narrow or wideband?
Perry
Wideband Dave. I think they are Bosch probes on my Zeitronix systems
ISTR wideband types are less tolerant of high temps than narrowband. Although that might have changed since I fitted mine.
