Good evening,
Bit of back ground, I rebuild the v8 thor lump using 4.6 crank and rods 4.0 pistons, torque max cam, all valve / tappets set etc
The disco has never seemed to run right even before the rebuild I have changed maf sensor ( 6 in 8 years ) using gen sensors, new O2 sensors but......
When diving at low revs <3k it feels like something is holding the engine back, when it gets above 3k it's like someone throws a switch and it takes off, no matter what I do I can find what the problem is,
I have had to unplug the 02 sensors as it was just backfiring and really wouldn't run at all, so unplugged them and reset adaptive values and now I have the other problem
Wish I could change management but it controls so many other things, gearbox, slabs etc.
Any one and ideas? Hate the bloody thing ATM,
If it makes any difference it also runs on LPG.
Si
Disco 2 v8 causing more problems!
