do i need the bypass pipe
chris-stockton
- Helpful or Confused
hi guys,
i could really do with getting the thermostat housing with the straight outlet for the westy, but the dont come with the outlet for the bypass pipe.
Do i really need to run the bypass?
93 tvr chimaera 430
91 westfield 430
91 westfield 430
chris-stockton
What about a thermostat with a couple of holes drilled around the edges?
Or no thermostat at all(just knock out the centre) as I am sure the engine and rad will get hot pretty quickly in a Westie!
Possibly but it could also create a circuit with less resistance than through the radiator and thus all the water would bypass and the engine end up cooking itselfunstable load wrote:If he doesn't have a heater could he not simply have a hose from the pump outlet back to where the heater would enter the engine to complete the circuit and solve his problem that way?
chris-stockton
