Can anyone tell me the dipstick length for a Vitesse Block ? I have 2 RV8 dipsticks both of different length. I could just pour in the required amount of oil and measure the level then mark it, but that would be too easy.
Alex
Dipstick length for Vitesse Block
its not the block that they match as all the blocks are the same its the tube it goes into. Unless your 100% certain you know what the tube is from your better off either buying a new/second-hand set or fill engine with the right amount of oil and see what gives the right reading. Course that assumes you have the correct sump for the amount you put in.
